Drywall Above Tub Surround - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 09:36 AM   #1
drywall above Tub Surround
Hi
I am putting in a new bath tub and I removed the old tub and drywall and I am installing a new tub and tub liner.
I am using the water resistant drywall.
My question is, can the tub liner end just above the shower head or does it need to extend to the ceiling.
Craig
PS. I never knew till yesterday that my old tub was cast iron, what a pain it was to remove.
Craigsutton is offline   Reply With Quote
Old 03-14-2009, 07:56 PM   #2
Drywall contractor
Rewards Points: 1,070
By "tub liner" are you referring to a fiberglass tub with a fiberglass surround or are you going to install a tile surround?? Either way the surround normally stops at 6' from the floor. The shower head protrudes through the wall 4 or 5 inches above this. If you are tiling, you could extend it to the ceiling (and it should be applied to backer board, not directly to the drywall). A fiberglass surround is a fixed height with drywall above to the ceiling unless you want to add tile on up to the ceiling........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
