Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-02-2006, 10:29 PM   #1
Drywall
I recently removed tile from my bathroom wall and I need to remove the plaster behind. The existing tile did not go to the ceiling I am wondering is it possible to drywall that have and mix it with the plaster or should I re-plaster all the walls? Or would it be a wiser decision to drywall the whole bath?
Dansad is offline   Reply With Quote
Old 10-03-2006, 07:23 AM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Question is a little confusing. Are you asking if you can drywall along side plaster walls? The answer then would be sure. I did it in my own bathroom not long ago. The important thing is simply that you make sure you fur the drywall out to be level with the plaster before taping and mudding your seams.
J187 is offline   Reply With Quote
Old 10-03-2006, 06:22 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you can use joint compound over the plaster areas. Done it alot. Even over areas where tile has been ripped off in bathrooms, just like you described. Tho, I would suggest that you use the ready-mix kind . That is the durabound, that is purchased in the bags and you mix with water.
Get the 90 minute kind, so you have plenty of time to work with it.
You will need to do several coats to get it right.
Good luck
- Build Well -
Old 10-05-2006, 01:46 PM   #4
J187's Avatar
Rewards Points: 516
Dansad, is that what you were looking for?
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
