Dryer Vent Through Vinyl Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2008, 09:18 PM   #1
Rewards Points: 264
dryer vent through vinyl siding
Need to relocate a dryer vent. Siding is vinyl, dutch lap profile. Can someone point me to information on cutting the siding to install a vent block? I have the 2 piece vent and need to know what to do to cut the siding and attach the vent.
Thanks!
7echo is offline   Reply With Quote
Old 12-13-2008, 09:30 PM   #2
Electrical Contractor
kbsparky's Avatar
We simply cut a 4" hole, just large enough for the dryer vent ductwork to fit.
You can insert some plywood pieces into the exposed edges of the siding to prevent it from collapsing if you like. Then securely fasten the vent hood to the wall, and install a small bead of caulk around the outside edges to prevent leaking, and damage to the sheathing.
Or, you can buy a siding block and put that in first, and then install the vent into that. More trouble, however ...
Old 12-13-2008, 10:30 PM   #3
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
This thread might be of help to you also...
Cutting through sill for dryer vent
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 12-15-2008, 07:23 AM   #4
Thanks!
First question is what is current temp outside? (It's Cold in Michigan) Cutting siding in cold weather, combined with age of siding, It may crack or break while cutting. Go to nearest seam and gently pull apart , You may have to pull several pieces apart around area, Remove if needed. Cut hole for vent, cut hole in block, Nail to house, cut siding to fit around block, Now comes the tricky part. you need a siding zip tool. (Home improvment store $10.00) take tool on bottom edge of siding, pull down gently and use other hand to push siding back togather. Install ring around block. Finished!
butlersprints is offline   Reply With Quote
Old 12-16-2008, 06:07 PM   #5
Rewards Points: 5,336
Georgia, High of 70, low of 51. It's a living hell.
To install the block, use a sharp utility knife.
Ron
Old 12-19-2008, 08:07 PM   #6
Rewards Points: 264
Thanks!
Thanks for comments.
BTW, today it got up to about 80 and was sunny. Shouldn't be a problem cutting the vinyl.
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 08:44 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
