Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-14-2012, 01:38 AM   #1
dryer vent
how do you put a dryer vent through vinal siding thats already up
dickiedo is offline   Reply With Quote
Old 07-14-2012, 11:18 AM   #2
dryer vent
Your going to need to go pick up a dryer vent siding block with the J moulding trim built in.
The siding is removed in the area where the vent is going to be.
Use a long drill to drill a 1/4 hole from the outside all the way through the wall so you can see where it's going to come out to double check there's nothing in the way.
It's best to use a 4-1/2 hole saw to make the hole from the outside, once it breaks through clear the plug out of the hole saw reach inside the hole and clear the insulation out of the way. Then go inside and make the hole through the sheetrock.
SLide the vent into the hole from the outside, check it for level and nail it to the sheating.
Now the siding can be reinstalled, leave about 3/8 all the way around the siding block so the siding has room to expand and contract.
And no you can not leave the siding in place and just cut a round hole through it.
dickiedo (07-15-2012)
Old 07-15-2012, 12:10 PM   #3
Wink
dryer vent
thanks that helps a lot
Old 07-16-2012, 11:04 AM   #4
Willing to listen
dryer vent
I would only add to be aware of location of placement, understanding that there are always obstacles. We see many installed near the air conditioning outdoor unit and it's a problem with loading the AC units fins with lint.
Done That is offline   Reply With Quote
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing 4 07-27-2010 11:39 PM
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
