Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-28-2012, 09:02 AM   #1
Drop in tub frame
I have purchased a 6 ft. soaker tub and removed the old tub. I now need to build a frame for the new tub which which can be tiled and have a granite surface which the tub will be dropped into. How do I buld the frame?
ottumwa is offline   Reply With Quote
Old 06-28-2012, 09:09 AM   #2
Drop in tub frame
The directions should have been with the tub, or go on line and look them up on that companys web site.
There is no one set of instrutions that fits all tubs.
You ripped this all apart and now you want to know how to build it? Hmm.
Old 06-28-2012, 10:01 AM   #3
Super Moderator
Drop in tub frame
Typically a 2x4 stud knee wall or box--covered with3/4" bc plywood--then topped with 1/4" cement board--
More info needed--how many walls--how is the deck shaped---access panel needed?
mae-ling (06-28-2012)
Old 06-29-2012, 11:23 AM   #4
DIY-er
Drop in tub frame
Hi Ottomwa:
Build the 2 x4 wall as Mike suggests, and look on the tub manufacturer's website for instructions on building the bottom slope properly. This is very important to ensure that the tub drains properly. The instructions will give you the precise angle that you need to build. I repeat, very important to build the angle correctly.
KevinPh is offline   Reply With Quote
Can the hot wire be under tension in an overhead drop?? WillK Electrical 15 10-08-2011 02:40 PM
Service drop too low above garage WillK Electrical 1 09-19-2011 01:00 PM
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 01:39 PM
Drop Rate on Scott's Drop Spreader SPS-1 Landscaping & Lawn Care 1 04-28-2009 09:24 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
