Drop In Tub Decking - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-27-2007, 06:06 PM   #1
drop in tub decking
Is it possible to use Wilsonart Laminate for the tub decking?
smstrs is offline   Reply With Quote
Old 10-27-2007, 06:11 PM   #2
If you are very confident that you could keep water away from the seams, I spose you could use it.
send_it_all is offline   Reply With Quote
Old 10-27-2007, 07:03 PM   #3
I do not plan on having a seam. I am planning on cutting from one 4x8 sheet of laminate.
Old 10-28-2007, 09:07 AM   #4
i think it's possible to use laminate for tub decking and it's inexpensive, too.
Undermount Sinks
Kitchen sinks is offline   Reply With Quote
Old 10-31-2007, 07:51 AM   #5
I used plywood...with three coats of primer...and then three coats of oil based paint
The only part of the decking that is exposed are the four inches on the long near side
lee polowczuk is offline   Reply With Quote
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 09:12 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Plastic decking? kcrossley2 Building & Construction 4 10-08-2007 10:59 AM
