Drop Ceiling...what Is The Minimum Drop? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 09:03 PM   #1
DIY Expert in Training!
Drop ceiling...what is the minimum drop?
I am planning on installing a drop ceiling in my laundry room. I don't want to lose much space...what is the least amount of drop I can do?
gone_fishing is offline   Reply With Quote
Old 02-24-2008, 09:48 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there is a ceiling system that the grid attaches directly to the floor joists. Most folks I have talked to do not like it.
other than that, the lights used is usually the determining factor as to how much room you need. The less room you have, the harder it is to install and/or remove the tiles but I have had carpenters build my light in place because the space was so shallow, I could not install as usual.
Old 02-24-2008, 11:13 PM   #3
Rewards Points: 16
It depends on wires, pipes, lights and anything else in the way. Generally a 3 inch drop is minimum for getting tiles in and that is tight. Ceiling max is the grid that is installed tight to the joist and is sold at home depot. It isn't the easiest to work with but it is a decent product once you figure it out.
ponch37300 is offline   Reply With Quote
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 09:04 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
Pool Table Light in Drop Ceiling JJdeadhead Electrical 5 04-18-2007 09:01 AM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 08:52 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
