Drop Ceiling With Steel Floor Joists - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 08:50 AM   #1
Drop ceiling with Steel Floor Joists
I've been working on finishing my basement and I've been planning on putting a drop ceiling in. The walls are in place and finished, and I'm ready to move onto my ceiling but I'm not sure how to begin. The floor joists in my house are steel, not wood and I am not sure what the best way to attach the hangers for the ceiling to the steel floor joists would be.
Here is a picture of the joists in my basement:
Thank you to anyone who can provide me some assistance on figuring this one out.
stanlemon is offline   Reply With Quote
Old 11-16-2010, 09:48 AM   #2
Rewards Points: 1,010
Normally a drop ceiling is a grid or t-bar ceiling. If that is the case, the hangers drill into the bottom of the flanges with "penetrators", or sheet-metal screw into the side of the web
Anti-wingnut is offline   Reply With Quote
Old 11-16-2010, 12:09 PM   #3
Thanks for the reply! I'm not sure I know what you mean by "penetrators"?
Is there any point at which I need to be concerned about compromising the integrity of the joist by drilling in to them for a project like this? I'm assuming not, but as I have literally no experience with steel floor joists I figure it doesn't hurt to ask.
Old 11-16-2010, 01:53 PM   #4
Rewards Points: 5,336
It looks like you have holes in the joists already. You should be able to use those to set up a support system for the grid.
Ron
Old 11-16-2010, 02:10 PM   #5
The holes you see in the picture are on the side of the joists and are used for threading the electrical around. I assumed I had to hang the ceiling from the bottom of the joists... So I can use the electrical holes?
Old 11-16-2010, 04:11 PM   #6
Why not? You can use an eye bolt system to bridge the areas you need the hangers. Just plan the installation and put the hardware you need it.
Just check to see what loads the beam will support. If you use the fiberglass ceiling tiles, there won't be an issue as they're very light.
Ron
Installig Ceiling fan in drop Ceiling BatmanDIY Electrical 2 09-07-2010 12:29 PM
o I really need a drop ceiling over my bathtub? chkaryti Kitchen & Bath Remodeling 2 11-13-2009 06:09 AM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 02:00 PM
Multi-level drop ceiling lb37illinois General DIY Discussions 6 11-15-2008 03:30 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
