Drop Ceiling Problem - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 02:03 PM   #1
Unhappy
Drop ceiling problem
We have a dropped ceiling made with Armstrong 2x2 tiles. although these tiles are fairly thick, the corners want to sort of "curl up" and we don't know how to get them to lay flat. Any suggestions? Thanks!
Bandit37804 is offline   Reply With Quote
Old 01-30-2010, 10:48 PM   #2
Rewards Points: 160
curling up from being wet or being too tight in the brackets?
hellothere123 is offline   Reply With Quote
Old 02-01-2010, 01:34 PM   #3
Rewards Points: 12
How old are the tiles? I don't think the corners are "curling up", I would bet the middle is starting to sag. This will happen with some tiles over time. Or if the get wet. Do you have any pictures of this "curling up"?
ponch37300 is offline   Reply With Quote
Old 02-01-2010, 04:27 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Pretty common depending on the style and age of the tile. And whether there is a lot of stuff loaded on the tops of the tiles, such as flex duct, wiring or insulation. A lot of places use tegular tile that drop down below grid level so that the curl is less noticable.
http://www.armstrong.com/resclgam/na...itemId=45140.0
Old 02-04-2010, 01:34 PM   #5
Drywall contractor
Rewards Points: 1,070
Pictures would help.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 01:39 PM
Ceiling Fan Installation Problem ejbende Electrical 6 09-01-2009 10:35 AM
Custom homemade drop ceiling slowboyy Building & Construction 11 06-03-2009 07:16 PM
Ceiling problem yo_paully General DIY Discussions 12 08-28-2008 07:09 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
