-   -   Drop ceiling in basement bathroom (http://www.diychatroom.com/f15/drop-ceiling-basement-bathroom-6689/)
handyflyer 02-24-2007 04:51 PM
I am currently finishing my basement and I will be doing a drop ceiling in most of the basement. Has anyone heard of any problems using a drop ceiling in a bathroom?? It will be a full bathroom with a tub/shower unit and a properly sized exhaust fan vented outside of course.
redline 02-24-2007 05:00 PM
How tall will the finished ceiling be?
Darylh 02-25-2007 10:03 AM
Biggest problem of course is moisture. Make sure the fan is slightly bigger than you need and is wired to the light switch so it comes on everytime you go in there.
As Redline asked "how high will the finished ceiling be?
And when you say "Dropped ceiling do you meam Its going to be a ceiling than you are going to drop and then drywall or do you mean its going to be a dropped t- bar ceiling with panels.
I would never put a t-bar ceiling in a bathroom myself but if it is a dropped ceiling thats going to be drywall then no problem just make sure to do two coats of drywall sealer and two coats of oil based paint and follow my advise at the top of this post.
handyflyer 02-25-2007 07:35 PM
The finished height is going to be 7' 5". Aren't there some vinyl tracts out there that can be used in a bathroom??
AtlanticWBConst. 02-25-2007 08:54 PM
In the building industry, 'dropped ceiling' means = Acoustic ceiling....
Darylh 02-26-2007 08:23 AM
Please correct me if I am wrong but if Accoustic ceiling panels get moisture in them won't they warp.
AtlanticWBConst. 02-26-2007 10:39 AM
We use armstrong ceiling products. This is what is stated on their website:
Can Armstrong ceilings be used in the bathroom?
Yes, if the bathroom is vented to the outside with a fan. Armstrong ceilings with HumiGuard™ Plus are extra sag resistant for use in areas of high humidity. BioBlock™ Treatment inhibits the spread of mold and mildew.
Will the ceiling sag over time?
No, if the ceiling is installed according to its warranty. Armstrong ceilings are treated with a special back coating to resist moisture. When properly installed under the right conditions (no excessive humidity, etc.), they remain level and flat. We recommend using HumiGuard™ Plus panels or fiberglass panels in areas of high or seasonal humidity; they are not recommended for spaces exposed to continuous moisture, such as shower rooms and swimming pool areas.
(FWIW - I would install Sheetrock in a bathroom ceiling that has a shower or tub in it ....)
Darylh 02-26-2007 10:10 PM
What I find most of the time in this business is that ceiling fans pull the heat out of the Bathroom so people tend to not use them all the time so that is why I said to put the fan on the light switch so its on every time especially in a drop ceiling bathroom. I still go with drywall myself.
Aren't there some vinyl tracts out there that can be used in a bathroom?? Yes, I just took some down but check with the supplier.
Thanks for the info Atlantic...
STEPHENWANGEL 03-02-2007 03:40 PM
Plastic no rust ceiling grid
There is a company called acoustic ceiling products that makes plastic suspension grids for dropped ceilings. They also manufacture a track that attaches right to the joists so that you don't lose any height. I used it in my own basement... worked GREAT!
http://acpideas.com
:thumbup:
bjbatlanta 08-24-2008 09:45 PM
You can buy tile that is sheetrock with a vinyl face that is ofter used in commercial applications where moisture is a factor or periodic cleaning is required (kitchens). I believe I have seen it at Home Depot. If they don't carry it, any drywall/acoustical supply will have it. Personally I would frame the ceiling down and use sheetrock if possible.
Termite 08-24-2008 11:02 PM
A grid ceiling in the bathroom is less than desirable, although it will work. I'd opt for a framed and sheetrocked ceiling for sure...Much more professional. The grid ceiling won't do anything for the home's value, and will detract from the overall appearance of your bathroom project.
With a proper installation of the appropriate grid ceiling products, it should perform just fine.
Girlbuilder 05-16-2009 03:00 PM
Drop ceilings for the bathroom
Hello! I have a drop ceiling in my old victorian house in the bathroom and the kitchen. You have to find ceiling tiles specifically for these areas. I have found them on line. The ceiling tiles are moisture resistent. My old ones have a fiberglass backing and have never had mold on them. Just say - yes we can!:yes:
Girlbuilder 05-16-2009 03:05 PM
Drop Ceiling Tiles
I have an old victorian house with a drop ceiling in the bathroom and kitchen.
You have to find ceiling tiles just for this area. I have only found them online. My old ones have a fiberglass back and have never had mold on them. Just say - yes you can!
Here's the website below for bathroom ceiling tiles.
http://www.ceilume.com/ceilingtile_d...n=CeilingTiles
Drop Ceiling tiles
:yes:I have an old victorian house with a drop ceiling in the bathroom and kitchen.
http://www.ceilume.com/ceilingtile_detail.cfm/title.Polyline_Ceiling_Tiles-size.24inches_x_24inches-color.White-productID.434?utm_source=oldsite&utm_medium=produc tlink&utm_campaign=CeilingTiles
bjbatlanta 05-16-2009 04:35 PM
You still run the risk of the grid itself rusting from prolonged exposure to the humidity if you don't have proper exhaust venting (bathroom especially.) I think that was everyone's concern with the original post.....
