Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-21-2010, 08:33 PM   #1
Drip edge on bottom side of window sill...
I am going through my house window by window restoring them. THey are double hung with big sills. I just noticed that the underside of the sills don't have that little groove that modern windows have, which i presume to be a drip edge. Questions are -- is it worthwhile to cut one in while I am already working on the windows, and how would I go about doing so with the sill in place? Thanks for any insights.
Windows is offline   Reply With Quote
Old 03-21-2010, 11:15 PM   #2
jlhaslip's Avatar
is the bottom of the sill horizontal or tipped down?
If there is a tip to the sill or apron, you won't (shouldn't) need the kerf cut.
consider using a palm router with a spline bit.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-22-2010, 02:40 AM   #3
Thanks for the advice. They are horizontal and from the way the paint has peeled under the sills, I should have guessed a kerf cut would be necessary. Thanks again.
epdm and drip edge devilleather Roofing 5 11-08-2009 10:44 PM
FELT: over or under drip edge? Magpie's Friday Roofing 12 05-09-2009 12:43 AM
Roof Vent Drip Edge porschedude996T Roofing 6 02-04-2008 02:03 PM
Drip edge on a shed roof. Scott Roofing 2 10-04-2006 08:22 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
