Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-14-2010, 03:14 PM   #1
Drilling asbestos siding (hanging shutters)
I'd like to hang shutters by my windows,to dress the house up for curb appeal,to help better a sale on my home.
The house is a cape cod,built in 1950 and has wonderful asbestos siding on it,which I recently had painted. This siding is in 100%,perfect condition the entire way around the house.
I've searched this DIY forum for some tips on drilling asbestos siding,but the closest I found was folks discussing cutting holes in asbestos siding. Never really mentioning any drilling techniques.
I am hell bent on hanging these shutters cause myself and my real estate agent think they would look great and help the sale.
My questions(s): What is the best technique for drilling asbestos,shingle siding,without cracking or breaking the siding itself?
What type of bit would I use?
What type of anchoring would I use to secure lightweight,plastic (wood simulated) shutters?
Yes...I am well aware of the hazards of working with airborne asbestos dust. I have done extensive research and I got all the necc. safety gear to work with it. Gloves,safety glasses and safety sheild and a charcoal canister dust mask.
Keep in mind,I am not removing,repairing or replacing the asbestos siding...just looking to drill some holes without cracking or breaking what is already in place.
thank you all in advance for any tips you might have.
I'll log back in tomorrow morning when I get off work
Michael
MichaelDutch is offline   Reply With Quote
Old 06-14-2010, 09:05 PM   #2
Tom Struble's Avatar
1/4''carbide masonry bits usually work the best for me,maybe mist the area as your drilling to control the dust,use the fasteners that come with your shutters,either will be color matched screws or plastic plugs
if using the screws just drill thru the siding with the 1/4'' bit then switch to the appropriate size drill bit and drill a pilot hole for the screw thru the sheathing
for the plugs drill the 1/4'' bit thru the siding and sheathing then just push in the plugs until they are seated to the face of the shutter,don't hang them too tight or you will distort them
and don't drill to deep,there are wires and pipes in walls sometimes
Tom Struble is offline   Reply With Quote
Old 06-15-2010, 11:02 AM   #3
Cool Breeze's Avatar
If you have one available to you, a corded drill trumps cordless in this instance. The true asbestos shingles are easier to get through than the replacement cement shingles, but it is still a bear of a job if you're using an underpowered drill.
Cool Breeze is offline   Reply With Quote
Old 06-15-2010, 11:49 AM   #4
tomstruble...unfortunatly. The shutters I purchased are used. I found them at a habitat "ReStore" for a great price. Thank you for your tips. I'll be sure to go with 1/4 inch carbide masonary bit. I'll grab several at the hardware store,as I have 12 shutters to hang and I'd hate to be into the project and the bit burn up. yes...already planned on misting to control dust.
cool breeze...luckily for me,I recently purchased a really nice,variable speed corded drill
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
Cutting asbestos siding Marvin Gardens Building & Construction 22 12-06-2008 06:00 PM
Assuming Asbestos Tile mcconnre Flooring 35 11-14-2008 02:56 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 08:27 PM
