Doorless, Open Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 02:54 PM   #1
Great forum btw. Just starting work so I will be busy here. I plan on doing a 60x72 shower, with full height walls in the corner, a 42" pony wall on the 60" side and leaving it completely open with a near curbless entry on the far end. The shower heads will be on rails in the farthest corner. My bathing experience shows that i will get little or no spray escaping at the far end, and maybe just a mist at the pony wall side. Question is "how successful does a near doorless open shower function to those who have experimented with them." Thx!
Jkatfish is offline   Reply With Quote
Old 03-12-2014, 04:40 AM   #2
Rewards Points: 4,538
we have both - frameless here but traditional showerhead,,, will have open in atl but using the newer rainforest ( idk, ask my bride, nagzilla ) type showerhead - 8" diam & flows straight down if i explain it correctly
ps - full encyclopedia britannica for sale - my bride knows EVERYTHING !
Old 03-12-2014, 12:47 PM   #3
Bill Kearney
Rewards Points: 1,174
Kinda depends on where you live. But personally I dislike open showers. You immediately lose any of the warmth typically retained with a space that can be closed. That and there's almost always overspray or splashing cast off from occupants, including soap products. Better to be cleaning that off tile, glass or a curtain than nearby drywall.
Frame vs frameless is a matter of personal preference AND practicality. We have frameless in the master shower (also 72x60). It has rubberized 'seals' around it and does a great job of enclosing the space (it's also a steam shower).
But in our child's bathroom we specifically chose NOT to go frameless. Mainly because framed doors can withstand a lot more abuse. Frameless glass is sensitive to edge-on impact, so a child doing something like leaving a hard toy in the gap and slamming the door poses a greater risk of the glass getting broken.
wkearney99 is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 11:05 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 07:43 AM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
