Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-19-2009, 08:00 PM   #1
DIY Expert in Training!
Door trim in tight areas???
I am finishing a remodeling project. The one door has vent soffits above both sides and is tight to one wall. Therefore, on one side I can fit traditional trim on both sides but not the top. On the other I only have about 1 1/2 on the right, 3-4" on the left and 1 1/2 on top.
How do you suggest trimming this out?
Thanks!
Kevin
gone_fishing is offline   Reply With Quote
Old 04-19-2009, 08:40 PM   #2
Moderator
Center so one side casings are same width. If door is not near another, cut jambs and door down to get head the same as casing width. You won't see both heads at once. Be safe, GBR
Old 04-19-2009, 08:55 PM   #3
Door is already in place so altering casing and door are no longer an option. I have two ideas:
1st: Use my normal trim, rip top piece to fit and then use angles to match up miters.
2nd: Use 2" pine and rip to size. Simply run like a box.
Old 04-19-2009, 09:24 PM   #4
Xtreme DIY'r
I'd match whatever style of trim is in the same area
In most cases I see the trim cut to fit
One window I have is close to a wall
That side is simply cut thinner to fit
Old 04-20-2009, 10:43 AM   #5
Rip the trim to fit. I have done this before and it is hardly noticable.
ponch37300 is offline   Reply With Quote
Old 04-21-2009, 08:57 AM   #6
Ponch...did the first door this morning. Looks pretty good. Will post pictures once I am done the project.
Old 04-21-2009, 09:18 AM   #7
They're all fixer-uppers
J187's Avatar
if you caulk it well, it will look fine. I've done this in my house as well.
J187 is offline   Reply With Quote
Old 04-21-2009, 09:24 AM   #8
glad it worked good for you.
Stained deck and it rained - some blotchy areas?!?! curls00 Painting 3 06-24-2008 05:18 PM
Floorboards "warping" in different areas of house sandi Flooring 5 06-06-2008 04:15 PM
Uneven areas in tile backer Richo Flooring 1 01-04-2008 08:33 AM
High low areas in my lawn jerry1967 Landscaping & Lawn Care 3 11-29-2007 12:46 AM
When/how to seed grass in dead areas? curls00 Landscaping & Lawn Care 8 07-29-2007 01:25 AM
