Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-23-2012, 02:03 PM   #1
Question
door-subfloor clearance
when framing a door opening and there is only subfloor and not finished flooring yet, should i plan that the bottom of the door frame touches the subfloor or should i provide for some nominal clearance that would be comparable to the finished flooring thickness (e.g. 1/2" or so) ?
i don't necessarily have to put the door in but i do need to put the horizontal top frame plate in order to hang drywall...
thanks
Old 04-23-2012, 02:22 PM   #2
DIY Enthusiast
sublime2's Avatar
Frame should be on the floor.
The finished floor can be put down around it or the frame can be cut to accommodated height to the type of flooring.
Don't want to cut it now and be short for some reason when the floor is installed.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
amakarevic (04-23-2012)
Old 04-23-2012, 02:27 PM   #3
exactly what i thought but wanted to confirm.
thanks
Tags
door frame
