Door Jamb Too Large - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-08-2008, 04:05 PM   #1
banging thumbs
Door Jamb too large
When we ordered our exterior door, we measured the existing jamb with the old door still in place. Now that the custom door has arrived, it appears that we must have measured the trim as well. Now that the old door is out, the actual jamb is 4.5" and the door we ordered came with a 5.25" jamb. How screwed am I? Is there anything I can do with the new prehung door to make it work?
Thanks.
bakerhouse is offline   Reply With Quote
Old 05-08-2008, 04:49 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Install the door and the casing will intrude .75 inch inside past the dry wall or plaster. Hold up the casing you will be using and mark where in falls on the wall. Measure from that mark back to the jamb and rip pine (or whatever your casing material) boards that dimension less a .5 inch or so.
Trim around the jam with these boards and install casing on top. You will have the appearance of thicker than normal casing.
Old 05-08-2008, 09:41 PM   #3
Custom Cabinet Maker
Another way would be to get 1 x 2. lets presume the 3/4 depth, glue and nail 1 x 2 flush with outside edge of trim, then apply as normal. This way there is no measurement misses. You can also do this with just 3/4 x 3/4 parting strips. Attach b4 you cut the miters, be careful where you put nails, then use a pc of 3/4 on miterbox table to keep it flat, cut your miters. Normal 1 1/2 #4 on jamb but at the outside of trim you will need #8 or #10 penny finish nails.
skymaster is offline   Reply With Quote
Old 05-08-2008, 09:43 PM   #4
buletbob@optonline.net's Avatar
I would do the same but add the build out to the back of the trim and then cut and install it.
buletbob@optonline.net is offline   Reply With Quote
Old 05-09-2008, 06:18 PM   #5
banging thumbs
Thanks for all the tips. The door is in and I think everything is fine with the jamb. Looks good, closes good. On to the next problem, I mean project.
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 11:59 AM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 03:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 10:17 PM
