Door Framing Trouble - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 03:30 PM   #1
Door framing trouble
I installed a new door in my house a while back but haven't completed the finish work yet because I have no clue how to do it. here is my problem. I have attached four pics to help explain. The pine framing of the new door isn't wide enough to reach all the way back to the drywall. So, there is a gap. How do I frame this? I want to be able to install molding around the door soon. If you can't understand the problem I have from looking at the pics, I'll try to explain it differently. Thanks to all that can help me!
Tim
Door framing trouble-picture1.jpg   Door framing trouble-picture2.jpg   Door framing trouble-picture3.jpg   Door framing trouble-picture4.jpg
TaiwanTim is offline   Reply With Quote
Old 03-09-2012, 04:10 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Sorry. No idea what I'm looking at.
titanoman is offline   Reply With Quote
Old 03-09-2012, 04:14 PM   #3
ok, look at the second pic. On the left is the white door, next the pine frame, next is the gap, then the drywall. how do i cover the gap. It is about 2 inches. Does this help?
Tim
Old 03-09-2012, 05:04 PM   #4
Framing Contractor
Rewards Points: 120
You would install an extension jamb. Basically, it is a small strip of wood cut to size to come out even with the drywall.
sixeightten is offline   Reply With Quote
Old 03-09-2012, 05:49 PM   #5
Thanks. I think the biggest problem I had was not knowing the correct terminology (jamb extension) for the problem. Now I can google it and learn more.
Does anyone out there have any tips of the trade to make it error free?
Thanks!
Tim
Old 03-09-2012, 08:29 PM   #6
Rewards Points: 512
yes jamb extension or i call them build outs.
cut off the spray foam that came to far out so it doesnt get in the way.
measure from the frame to the outside of the drywall all the way around and find out how thick the jamb extensions need to be.
cut the pieces of pine to fit so its flush with the drywall.
i personally nail them together so its like a frame that fits in place.
then add shims in like your hanging a door brad nailing it into the wall.(i find if the build outs are less then 1 1/2" i'll brad nail them directly to the door frame)
i also like to give it a little reveal like trim cause quicker and easier then trying to flush it up to the frame and easier to chaulk the joint.
then nail your trim on like you normally would
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
jaydevries (03-09-2012)
Old 03-09-2012, 08:37 PM   #7
Rewards Points: 14,014
You also have to now scrap off all that caulking before the jamb extention goes in.
You should have ordered a door with the correct width jambs
Lowes carrys some great clear imported pine for this job, not cheap but it's streight and no knots.
Trouble with lighting circuit GPerry12345 Electrical 7 01-28-2012 09:43 AM
flat roof trouble winemaker1 Roofing/Siding 10 11-22-2011 01:30 PM
Just enough knowledge to get into trouble captain25 Introductions 1 03-23-2009 01:30 PM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 09:50 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
