Door Advice... Replacing Pane Of Glass And Refinishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 01:52 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Door advice... replacing pane of glass and refinishing
I have a wooden exterior back door that looks like this:
It's old, chipped and one of the panes is broken and the bottom mullion is missing. I'd like to replace the pane and fix up the door. While I'm at it, I'd like to make it look like this:
to match a nearby window.
I kinda like the way stop molding would look around the panes in place of the mullion - is it ok to use that instead? Also, how would you go about the crossing sections? I was thinking perhaps just gluing a flat molding directly to the glass and between the stop/mullion moldings? Any advice is appreciated.
J187 is offline   Reply With Quote
Old 11-30-2010, 11:17 AM   #2
Rewards Points: 5,336
You might try getting an insert made of thermal paned glass and install that. They can insert whatever grill pattern you want.
Ron
