Doing The Tub Surround Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 03:38 PM   #1
Doing the tub surround walls
Have a quick question. If I go the felt paper or poly behind the cement backer route, how does the water actually drain back into the tub? Won't the silicone seal between the tile and tub prevent any moisture from actually draining back?
russiand is offline   Reply With Quote
Old 06-26-2013, 03:48 PM   #2
Rewards Points: 20
You're supposed to leave some holes/gaps in the caulk between the tub and tile.
Dan
djlandkpl is offline   Reply With Quote
Old 06-26-2013, 03:53 PM   #3
Interesting never noticed that in any directions
Old 06-26-2013, 07:47 PM   #4
Rewards Points: 13,444
Never suppose to have a vapor barrier behind properly water proofed cement board!!!
Old 06-27-2013, 09:01 AM   #5
Strange that you say that. There exist at least 2 methods of doing a tub surround, with a moisture barrier behind the cement backer and one with a surface applied waterproofing material. Your statement about never is not quite correct and plenty of sources show that. You may have an approach that you like and that has worked for you but that does not mean that other time proven approaches as less correct. My question was about a specific detail of the moisture barrier behind cement board approach, which to the best of my knowledge is an industry accepted one.
The Following User Says Thank You to russiand For This Useful Post:
MTN REMODEL LLC (06-27-2013)
Old 06-27-2013, 09:08 AM   #6
Rewards Points: 20
Joe's point is you don't want to do both a vapor barrier AND a waterproofing membrane...that's bad. One is fine.
Dan
Old 06-27-2013, 09:27 AM   #7
That is a great point and no I would never do that, I am quite aware that this is not a good approach. I am just still wondering how to strategically place weep holes in the caulk for drainage...
Old 06-27-2013, 09:43 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,360
Russ.... Just honest to you....but your poly assembly (barrier.... not felt (retarder)), is a procedure/assembly that I've used alot.
Now, maybe I've been doing it wrong for 20 years, but I've not encountered problems.
I've never attemted to leave weep holes. I use it to prevent any natural moisture migration (from grout to cement board) from entering any framing members.... not as a drainage system.
I always figured, any moisture caught in grout or cement board, would naturally migrate out the way it got in.
Now, I am most interested in the sugestion to use weep holes.... can't imagine how that would work?
I'll stay tuned to hear this one.
Just my opinion.... always open to better ways.
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 06-27-2013, 10:12 AM   #9
Rewards Points: 20
The holes are recommended but when I did my surrounds I used a membrane and did not leave holes. I have the same opinion as Peter that the water will find its way out. If it was a steam shower or sauna I would leave the gaps but IMO, a shower wall just doesn't get wet enough to have the holes.
Dan
Old 07-17-2013, 10:13 AM   #10
So I finally demolished my tub and surround. Guess what? Regular greenboard behind the tile adhered with mastic. About 1/2 inch gap with tub lip, and only very, very slight evidence of any moisture penetration, must have been there for about 20 years like that. So in practice seems like many of our points are overkill anyways.
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 11:43 AM
Should I/ Can I get a permit for a redone tub and surround after it was completed? amodoko Remodeling 9 11-10-2012 06:02 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
