-   -   Doing the tub surround walls (http://www.diychatroom.com/f15/doing-tub-surround-walls-182548/)
russiand 06-26-2013 04:38 PM
Have a quick question. If I go the felt paper or poly behind the cement backer route, how does the water actually drain back into the tub? Won't the silicone seal between the tile and tub prevent any moisture from actually draining back?
djlandkpl 06-26-2013 04:48 PM
You're supposed to leave some holes/gaps in the caulk between the tub and tile.
russiand 06-26-2013 04:53 PM
Interesting never noticed that in any directions
joecaption 06-26-2013 08:47 PM
Never suppose to have a vapor barrier behind properly water proofed cement board!!!
russiand 06-27-2013 10:01 AM
Strange that you say that. There exist at least 2 methods of doing a tub surround, with a moisture barrier behind the cement backer and one with a surface applied waterproofing material. Your statement about never is not quite correct and plenty of sources show that. You may have an approach that you like and that has worked for you but that does not mean that other time proven approaches as less correct. My question was about a specific detail of the moisture barrier behind cement board approach, which to the best of my knowledge is an industry accepted one.
djlandkpl 06-27-2013 10:08 AM
Joe's point is you don't want to do both a vapor barrier AND a waterproofing membrane...that's bad. One is fine.
russiand 06-27-2013 10:27 AM
That is a great point and no I would never do that, I am quite aware that this is not a good approach. I am just still wondering how to strategically place weep holes in the caulk for drainage...
MTN REMODEL LLC 06-27-2013 10:43 AM
Russ.... Just honest to you....but your poly assembly (barrier.... not felt (retarder)), is a procedure/assembly that I've used alot.
Now, maybe I've been doing it wrong for 20 years, but I've not encountered problems.
I've never attemted to leave weep holes. I use it to prevent any natural moisture migration (from grout to cement board) from entering any framing members.... not as a drainage system.
I always figured, any moisture caught in grout or cement board, would naturally migrate out the way it got in.
Now, I am most interested in the sugestion to use weep holes.... can't imagine how that would work?
I'll stay tuned to hear this one.
Just my opinion.... always open to better ways.
Best
Peter
djlandkpl 06-27-2013 11:12 AM
The holes are recommended but when I did my surrounds I used a membrane and did not leave holes. I have the same opinion as Peter that the water will find its way out. If it was a steam shower or sauna I would leave the gaps but IMO, a shower wall just doesn't get wet enough to have the holes.
russiand 07-17-2013 11:13 AM
So I finally demolished my tub and surround. Guess what? Regular greenboard behind the tile adhered with mastic. About 1/2 inch gap with tub lip, and only very, very slight evidence of any moisture penetration, must have been there for about 20 years like that. So in practice seems like many of our points are overkill anyways.
