Does Drylock Waterproofing Help Reduce Radon? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-09-2008, 08:56 PM   #1
Does Drylock waterproofing help reduce radon?
Hi all...
I'm planning to finish my basement. House is about eight years old. It has poured concrete foundation walls. There are no water problems, but I'm thinking about applying Drylock waterproofing (latex-based) on the walls, and also sealing the concrete floor. My hope is that it might help reduce radon vapors, albeit just slightly. The last tested level is about 3 which below the action level, but I'd like to reduce it even further.
Any one know if sealing the floor and Drylock'ing the walls would help reduce radon? Or is it a waste of time and money?
Thanks for advice?
-G
nuadhu1 is offline   Reply With Quote
Old 02-10-2008, 06:47 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by nuadhu1 View Post
....Any one know if sealing the floor and Drylock'ing the walls would help reduce radon? Or is it a waste of time and money?
Radon gas can enter a house from many different areas. Sealing your foundation cracks and openings can help bring the level of gas entering down, but will not necessarily lower the amount of radon in a home.
Check your water source radon levels too.
(For the sake of other readers of this post: such an action WILL NOT STOP RADON GAS, and is NOT A STANDARD RADON GAS MITIGATION TECHNIQUE).
http://homebuying.about.com/cs/radon...adon_gas_3.htm
http://www.epa.gov/radon/pubs/consguid.html
- Build Well -
d.i.y. radon mitigation? smallcrpt HVAC 12 07-01-2015 01:18 PM
Options for waterproofing cement shed floor YNOTDIY Flooring 4 01-19-2008 10:31 PM
Radon Test Results handy man88 General DIY Discussions 3 11-20-2007 04:49 PM
Radon Test! handy man88 Plumbing 2 10-18-2007 07:38 PM
Anyone use Thoroseal or radon seal waterproofing products? dogdoc Building & Construction 2 05-17-2007 12:00 PM
