Do It Yourself Granite Countertops - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 11:26 PM   #16
Love for Construction
<*(((><'s Avatar
Originally Posted by Bob Mariani View Post
if you have the tools you can do it. Need something to hold the seams together until the epoxy sets. Maybe you can rent a vacuum clamp needed. The sink can be cut out with a 4" grinder (inside cuts) and a 5" saw both with diamond blades. I would not go with the thinner granite.
To keep the seams together while the epoxy sets just cut some pieces of plywood 3/8"x3/8"x4" and hot glue two plywood pieces across the seam from each other (do this before you put the epoxy on) and use spring clamps to pull the seam together tights the epoxy dries. You might need to use several pairs of plywood pieces glued down, depending on the length of seam. After the epoxy has set remove the spring clamps and take a hammer lying on the counter and tap the sides of the plywood to break the glues bond on the granite. Remove any glue residue with a razor blade.
<*(((>< is offline   Reply With Quote
Old 03-07-2009, 12:58 PM   #17
just hot glue, will it come off . i was thinking of pushing it together and clamping it from the bottom with C-clamps close to the seams . I was also thinking of using two suction cups and then try to clamp.
dalemercier is offline   Reply With Quote
Old 03-07-2009, 01:12 PM   #18
<*(((><'s Avatar
Yes, the hot glue will come of with a sharp tap with a hammer on the side of the piece of wood. You run the strips of wood parallel to the seam, within clamping distance of some spring clamps. Just make sure the hot glue has setup before trying to clamp, it doesn't take very long as the granite cools the glue pretty quick.
You don't need a tremendous amount of force to keep the joint together until the epoxy cures in the seam. One should pull the seam together with ones hands while someone else applies the spring clamps, it just needs to be static pressure, you aren't pulling the seams together with the clamps, simply keeping the seam together.
Either way, your clamping method underneath would work as well, but what do you plan on attaching your c-clamps to that is attached to the granite?
Old 03-07-2009, 03:50 PM   #19
I think i will try the hot glue idea . Now to the the underlay , do we use MDF OR MDO . Rona has MDO for $75 3/4sheet or MDF for $35 3/4sheet.
The MDO ply is only on one side not two . The MDF could only get wet at the sink . If I paint it around the sink cutout and i am useing top mountsink. OR pay more for the MDO sheet is it the much better and will it be still flat if is only one sided . What do other use it for other than sign's and boats.
Old 03-07-2009, 04:03 PM   #20
What is the best Diamond blade to use for my angle grinder. Will cut dry but I think that I could have someone sray with the hose a litle.
Old 03-07-2009, 04:16 PM   #21
Remodeling Contractor
Use a dry blade and have someone hold a vacuum by the blade. Better to use a 5" saw for straight cuts and most of the sink cutout to keep the cut square. Use the 4" angle to work around the sink and counter corners.
Exterior grade plywood is better for granite. The rough surface gives more adhesion to the glue. MDO for painted counters waterproof surface and very smooth. MDF for formica countertops so no movement under the laminate causing it to break loose.
If you have the vacuum clamps, use these. As posted you just need a stable grip on the joint, not much pressure. Glue you buy from HD and such may not hold very well and it may affect the sealer. (it shouldn't, but you have another way) Installers always use the vacuum clamps.
Old 03-08-2009, 08:14 PM   #22
Rewards Points: 1,016
recently had pre-fab granite installed
I recently had pre-fab granite installed by a company that does this. I considered to DIY'it, then decided not to - and glad I did not DIY. They had four guys onsite for the better part of a day to do the work. It was a lot of work by experienced guys.
Old 03-10-2009, 04:33 PM   #23
Thumbs up
Hi Iam thinking of buying precut to my sizes granite countertops. I would do the installation myself . With watching youtube and doing some reading on it , I think i could doit.But I have two options on grainte one is 2cm with edge and the other is thinner 1/2" with edges for 1 1/4 thinkness. I will be doing a surface mount sink,not under. So if i went with the thinner one you would not know. I will have to do two seams with epoxy that they will give me to match color of the countertop. I will also be cutting out for the sink but no polishing of edges
So what do you think about this
I was thinking of doing the same thing, that is, doing it myself. I ran across a small granite business that offered me a substantial discount if I would help out on the installation.
I learned a lot during the process. I think I would have made a mistake by doing it myself, but after just one hands on experience I would be confident in doing another installation myself.
This is my recommendations:
The construction business is real slow - translation- a great time for you to make bargains with a Pro.
If you are going to do it yourself anyway then try to watch one job in person or help out like I did.
If uou want to go ahead and without any of the above advice then I would suggest that you do three things:
1. Go with the thicker granite (less likely to break).
2. Make sure that the surface of the cabinets are Extremely level! Very important that all surfaces are of equal heights from the floor or you will have a disaster. Measure, measure, and measure again, you may even want to use a water level.
3. Two men are not enough you will need yourself and at least two additional men (three in all).
Once the granite is on the counter, move it very slowly in order to have different pieces of the granite come in contact with each other. If someone gives the granite a big shove and it runs into another piece of granite it will likely chip.
Good luck!
Botica is offline   Reply With Quote
Old 03-12-2009, 07:57 PM   #24
Thank you all for your help.
I was talking to the one company that Iam thinking of going with and on tuesday they are doing an Installation . I will be going to watch them do the install and get to see they finished work. I will be watching not helping at all. If it does not look good I think I will be going with 3cm and they will install it . I do not that there is to many out there that will let DIY. It going to be alot more $.
Old 04-24-2009, 12:43 PM   #25
If you do DIY- watch what you use as an adhesive, I've heard that some types of liquid nails can stain from the underneath. In other words you'll see dark spots where the liquid nail was placed underneath the slab. Yikes!
Granite countertops
granite-girl is offline   Reply With Quote
Old 04-24-2009, 07:53 PM   #26
just finished
I went with 3/4 granite and i did not have to do any cutting myself.
The company was a pre-fab granite not a slab . They cut it to size and did my sink hole with a water jet . I paid to have it deleverd and layed on my counter . If you have any questions .YES IT CAN BE DONE !!!
Old 04-24-2009, 09:10 PM   #27
Granite countertops
Yes, regular Liquid Nails construction adhesive will stain marble and granite. IIRC, it even states that on the label. They do, however, have a formula specifically for marble and granite; that's what was used in our kitchen granite installation.
clintb is offline   Reply With Quote
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 07:32 PM
Granite Countertops and Restaining kennykenny Remodeling 64 05-01-2009 11:15 PM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 01:00 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 08:23 AM
