Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-15-2011, 09:09 PM   #16
Do you think this wall is load bearing?
I am curious what the structural engineer said. I would love to hear what your solution was.
blinky114 is offline   Reply With Quote
Old 05-15-2011, 10:18 PM   #17
The SE said it was not load bearing. The wall has been down for close to two months now and no issues (knock on wood!!). Obviously if he was wrong it might take a while to have any issues but none so far
rchickering is offline   Reply With Quote
Old 11-21-2011, 06:35 PM   #18
You're worrying too much. Let the SE look at the structural system, and he will know what to look for. It will be more a case of him asking you questions, so don't fret. What I see as strange is the middle truss having vertical wall studs, which usually indicates the wall below would be load bearing. However, it's probably a gable truss to take the drywall part in the raked ceiling spac, and therefore, the wall below can be non load bearing. The other trusses that span outside wall to outside wall can have any wall beneath and preferabbly, the bottom chords are independent of walls below. That's how trusses are supposed to work. The gabled truss could have been replaced by the same truss type seen in the photos, and walls would be non load bearing underneath. What else is puzzling is the corner built up post. Since it's quite substantial, it appears to have no purpose, unless there was meant to be a hotwater service tank in the ceiling space above this wall. The way its built suggests the wall is load bearing. Or it could simply be a carpenter-framer used to corner studs being massive maybe to take a beam to span the opening, not realizing the roof is trussed.
Cheers from Oz
JoJo-Arch is offline   Reply With Quote
Load Bearing Wall Removal Question! Please Help! Evil Scotsman General Discussion 2 10-25-2010 05:52 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 09:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
