We're looking to open up our stairwell which will help our small kitchen area feel bigger. We would take out the top portion of the wall and leave a 44" high wall.
The problem we're running into is if one of the sections we are looking at taking out is part of a load bearing wall.
The truss, that sits on top of this wall, is a standard gable truss. There is a span of approx 9' that is open after this wall ends. The ceiling is vaulted (see blue shaded area on diagram below).
A few questions:
1. Do you think this wall is load bearing?
2. What is the maximum span capacity for a gable truss?
3. If you believe this is a load bearing wall, is there a way we could remove the two studs in the center and try to reinforce what is left?
We are having a structural engineer out this week to take a look at it but I wanted to see what people thought and if there are any questions we need to be sure to ask him.
Thank you!
Layout of the area - wall to be removed is in orange.
Roof trusses run from left to right on this diagram.
This is the gable truss that sits above the wall.
A few questions:
Thank you!
