Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-14-2010, 04:24 PM   #1
do I need to frame my basement insulate with batt insulation?
I searched first, couldn't find the answer to this. Our basement is half-insulated with batt insulation. I wanted to insulate the bottom half with batt insulation but I don't know if I have to (or should) frame the basement.
I read this: http://www.buildingscience.com/docum...ts?full_view=1
It says it's most common to frame the basement and insulate between the studs, but I'm not ready to do this yet. I just wanted to insulate the bottom half before our 2nd energy audit is due in a couple months.
y2chuck is offline   Reply With Quote
Old 02-14-2010, 06:26 PM   #2
Remodeling Contractor
if you are not finishing the basement walls you can leave it alone. Do not use the batts you see on the top part for the bottom part. Air flow is different between these areas. Now for the energy issue. The top 2/3represents 70% of the heat loss. the bottom is only 30%. Sealing the rim joists with spray foam (only good method) will yield far greater value and energy savings. If you also want to save more fasten 2" rigid foam boards to the bottom section.
Old 02-14-2010, 10:40 PM   #3
Moderator
I agree: http://www.quadlock.com/technical_li...Insulation.pdf
Be safe, Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 02-15-2010, 09:13 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated: Use ridgid foam board. Use multiple layers to build up to the R-Value needed/thickness of walls. Use spray foam to seal edges and gaps.
- Build Well -
Same old Question basement Insulation advice rp92285 Building & Construction 2 02-05-2010 12:01 PM
Beginning to plan finishing basement - insulation question ternstes Building & Construction 6 04-28-2009 10:47 PM
basement insulation questions CooperChloe Building & Construction 3 02-03-2009 08:54 AM
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 3 10-26-2008 02:16 AM
Basement Insulation Questions? BobR General Discussion 1 09-30-2008 10:25 PM
