Dismantle Steam Heat Radiator - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 02:17 PM   #1
Dismantle steam heat radiator
How do I dismantle a steam heat radiator into parts to be junked? These are larger radiators from a school in pieces.
Harry Martin is offline   Reply With Quote
Old 11-19-2011, 04:20 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 628
torch?, sledge hammer?
Old 11-23-2011, 07:38 AM   #3
Rewards Points: 1,548
If you are able to unscrew the rods that run horizontally through the radiator from end to end then the radiators may come apart into sections when hit gently with a sledgehammer. Otherwise the radiator is probably brittle enough that vigorous blows from a sledgehammer will shatter it.
Using Craig's List you might get some strong guys to come over and take the radiators away for you (or maybe you may even get some money for them), provided you did not shatter them first.
steam heat radiator Daniel52 Plumbing 1 09-09-2009 09:56 AM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
Help with STEAM Heat One pipe system johnnysanz3 HVAC 5 02-12-2009 10:10 PM
single-pipe steam heat - psi seems too high! ksg HVAC 3 01-30-2008 04:31 PM
Steam Heat - Radiator Enclosure Leah Frances HVAC 1 01-27-2008 01:49 PM
