-   -   Dismantle steam heat radiator (http://www.diychatroom.com/f15/dismantle-steam-heat-radiator-123980/)
Harry Martin 11-19-2011 02:17 PM
How do I dismantle a steam heat radiator into parts to be junked? These are larger radiators from a school in pieces.
chrisn 11-19-2011 04:20 PM
torch?, sledge hammer?
AllanJ 11-23-2011 07:38 AM
If you are able to unscrew the rods that run horizontally through the radiator from end to end then the radiators may come apart into sections when hit gently with a sledgehammer. Otherwise the radiator is probably brittle enough that vigorous blows from a sledgehammer will shatter it.
Using Craig's List you might get some strong guys to come over and take the radiators away for you (or maybe you may even get some money for them), provided you did not shatter them first.
