Digging Beside A "superior" Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 06:24 AM   #1
Rewards Points: 16
digging beside a "superior" wall
My basement is constructed of the precast "superior" walls. I bought the house about 7 years old, and I have no complaints with it, but one time I had water coming in around the sewer drain, which was about a foot off the basement floor.
From the inside, I enlarged the hole through which the sewer went through, so I could get a good layer of hydraulic cement in there. The wall was backfilled with small gravel, a large quantity of which came in through the hole I just enlarged.
. The walls do not sit on a concrete footer, but a bed of gravel. Now my question...I want to dig right beside the foundation How do I keep the gravel from running out from under the wall.
I questioned and was contacted by a rep from Superior walls, but he didn't really have a good answer... kind of a you'll just have to play it by ear, and figure it out. He wasn't smart or flippant about it.... just seemed that there wasn't a good answer.
I hope you folks may have a better answer... thanks.
realolman is offline   Reply With Quote
Old 03-21-2012, 08:20 AM   #2
If I understand correctly, you have a leak where the sewer pipe goes thru the wall??? If yes, just inject some expanding urethane foam into the opening. It will fill the hole and seal it up.
Old 03-21-2012, 04:05 PM   #3
Rewards Points: 16
I guess you were reading in English, and I was writing in dumbbell .
Thanks for your reply, though.
I discovered how small the gravel was that my foundation is backfilled with ( and I assume sitting on ) when I enlarged the hole for my sewer pipe. A large quantity of it ran back into the basement... much more than I would have expected.
Now, I want to dig beside and below the basement wall for a retaining wall, but I am afraid too much gravel will run out from under the basement wall... I wondered if anyone had any suggestions how to keep it under the Superior wall, or if I just dug beside it and let it run, if enough would run out to cause a problem. the hole for the retaining wall will be about 3' wide, and near the corner of the basement.
The Superior walls do not sit on a concrete footer, but a bed of gravel.
Old 03-21-2012, 06:58 PM   #4
Ravenworks's Avatar
The gravel it there to serve two purposes
1) it is there for a drainage
2) it is there to help relieve hydraulic pressure
The problem you have created now is a void on the other side of the wall,when you build your wall you'll need to have GOOD Drainage incorporated into it or the water will migrate.
Ravenworks is offline   Reply With Quote
Old 03-21-2012, 07:39 PM   #5
Rewards Points: 16
I guess I shouldn't have mentioned the sewer.
What I want to do is dig a 3' wide hole beside and below an existing "superior wall". Yhe superior wall sits on a bed of gravel. I am afraid if I dig beside it the gravel will run out from under the superior wall causing some sort of failure.
Can you think of a way I can prevent the gravel from running out from under the superior wall if I dig beside it deeper than it is, or do you think not enough gravel will run out to worry about?
Old 03-21-2012, 07:57 PM   #6
Ravenworks's Avatar
You may be able to pump some grout into the gravel in that area to help contain it?
I would worry about gravel loss if it were me because it is system the relies upon each other,IE wall holds gravel in,dirt hold gravel in gavel hold wall up.You lose one you risk losing the other.
As for the company you called,they are not going to advise you when it could make them liable.
I feel for you,but I know that you don't want to lose the footing
Old 03-21-2012, 08:08 PM   #7
Rewards Points: 16
thanks... You understand.
I thought about trying to get some runny cement ( grout ) into the gravel . I also thought about trying to drive something a bunch of stakes or maybe a bunch of flat steel stakes 2" X 1/4" ...or something like that along the wall .
Nothing seems to really trip my trigger as being a "yeah that'd probably work" idea.
So no one ever builds onto a building with a superior wall?
Old 03-21-2012, 10:27 PM   #8
Ravenworks's Avatar
Yes all the time,this is not typically a DIY ,I would imagine they would use a grout pump and inject the area that is to be worked on to stabilise it. If you don't you run the risk of failure. I would call a slab jacking company they have grout pumps and encounter stuff like this.What ever method you employ it better be fool proof.
Old 03-22-2012, 01:03 PM   #9
concretemasonry's Avatar
Rewards Points: 2,578
The gravel is a required item under the approvals for wall you described. I if it is a "Superior" wall system, it relies heavily on the gravel under the wall system and you cannot dig too close to it or under it. There is a prescribed width of gravel required because of the lack of a concrete foundation.
It is not a continuous wall structurally (such as poured concrete or block laid in running bond, but separated walls sitting on a gravel base, so that why the support is required in case the minimal ties are not enough for vertical continuity. They is probably why you did not get an approval or an semblance of a guarantee from the installer or manufacturer.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Ravenworks (03-22-2012)
Old 03-22-2012, 03:16 PM   #10
Civil Engineer
Rewards Points: 4,568
You have entered the twilight zone here, because any digging which allows the foundation gravel to shift is almost certainly going to void your warranty, which as I am sure you are painfully aware is a very big deal. Since Superior Wall clearly does not want to accept responsibility for foundation failure, and their product is not intended to have holes dug adjacent to it, they quite responsibly are refusing to tell you how to dig.
This is essentially an underpinning job. In my experience, you only undertake a job requiring underpinning when you have a very good reason to do so, and no reasonable alternative. If you have to do it, you may need to drive sheet piles adjacent to the wall, grout in place (as noted by other posters), or use bracing with walers. None of this is simple or free, and it is almost a given that any such action will void your warranty. My suggestion is to closely examine your project, and see if you can move the digging operation outside the foundation support zone, as defined by Superior Wall. If you absolutely have to dig adjacent to the wall, you may want to hire a contractor willing to guarantee in writing, supported by a bond, that your wall will not settle or collapse. If you insist on doing this work yourself, make sure your homeowner's insurance is going to back you up in the event of trouble.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 03-22-2012, 03:52 PM   #11
Rewards Points: 16
Thanks for all your input. Unfortunately, I don't feel any closer to a solution.
The reason for the digging is to replace a failed retaining wall perpendicular to the existing superior wall. the wall goes immediately beside the entrance to the garage that is in the basement formed by the superior wall.
Where the garage doors are, would they not have had to pour some sort of footer below the frost line? The walls would be pretty much sitting at finished grade, if not.
The retaining wall has to butt up to the superior wall. I don't see any alternative to just digging it out and taking my chances and hoping that the gravel doesn't run out enough to cause a problem. if it runs out, pour concrete in the void.... I don't see any alternative. I could probably try some sort of retaining wall that did not go below the frost line, but I don't see much hope in that either. I'm already removing one failed retaining wall
Although I know it is too late... I see no reason why they don't put those stupid things on a concrete footer. The water could be drained out just as well as having it sit on the gravel bed. If it wasn't anchored, the wall could expand or contract ( or whatever it's supposed to do) just as well on a concrete footer. I like the idea of the wall, but I think putting it on that gravel bed is just dumb.
Old 03-22-2012, 03:53 PM   #12
Ravenworks's Avatar
I agree whole heartedly with the two poster before me and suggest that you get the opinion of a competent person,such as an engineer.
In reality what you're dealing with is a house of cards,one wrong move and everything comes down.
I also want to retract what I told you about grouting the gravel,because grouting is only one part of a whole system involved in the modification.
Old 03-23-2012, 10:38 AM   #13
Smile
Superior Walls of America comments
What I want to do is dig a 3' wide hole beside and below an existing "superior wall". The superior wall sits on a bed of gravel. I am afraid if I dig beside it the gravel will run out from under the superior wall causing some sort of failure.
Can you think of a way I can prevent the gravel from running out from under the superior wall if I dig beside it deeper than it is, or do you think not enough gravel will run out to worry about? Thanks for all your input. Unfortunately, I don't feel any closer to a solution.
I work for Superior Walls of America. It is the company that licenses others to manufacture, install and sell the Superior Walls technology.
First, let me say that the job you are trying to undertake needs to be reviewed by a person competent in applying the structural design principals involved. In many cases that will be a structural engineer. Some builders may also be able to help or advise you.
Second, Superior Walls licensees allow builders to place the foundations on concrete footings if they so desire but that is not the prefered method for a variety of reasons.
Third, The crushed stone footing, however, does indeed present you with a different structural situation than a standard concrete footing but it is not an impossible situation. You just need to take into account all the loads and do not violate the law of gravity. You never undermine any foundation without considering the loads and making sure that you provide those loads with support at all times. Please review our technical resources to see if there are any ideas contained therein that may help you. Here is a link. http://www.superiorwalls.com/tech_resources
Specifically, I recommend that you take a look at our builder guideline booklet. Page 11 and page 12 illustrate a couple of situations where a wall may span a distance of 5' without support, but remember you still always need to adequately support the loads and make sure those loads are adequately transmitted to the supporting soil. When our factories originally design your walls they provide you with a foundation that will support all the anticipated loads as indicated on the design drawings for the project. The crushed stone footing provides you with superior drainage if installed according to our guidelines.
The best advice that has been provided to you so far was stated below by Daniel Holzman - he said
Feel free to contact Superior Walls of America if you want to discuss your options with our technical staff. As indicated by a couple of the gentleman before, for liability reasons we cannot provide you with engineering support, but we would be happy to help you understand your options and discuss your situation with you.
www.superiorwalls.com or 1-800-452-9255
EdinPA is offline   Reply With Quote
Old 03-23-2012, 04:43 PM   #14
Rewards Points: 16
I HAVE talked to someone from Superior walls. He did not have any specific advice, but more or less advised me that I would have to play it by ear to see if I could determine what needed to be done as I was doing the work.
Frankly I am a bit offended by the condescending tone of your post.
I never had any intention of "undermining" the wall, or "violating the law of gravity"... unfortunately, digging anywhere near it in a manner that would be acceptable with traditional construction, seems to pose an unusually high chance of THE SUPERIOR WALL UNDERMINING ITSELF, due to substitution of a concrete and rebar footing with a bed of gravel.
I need to dig a 3' wide ditch below the frost line up to the Superior wall , and I need have this reviewed by a structural engineer??? It would probably be less expensive to fix whatever damage may result.
I am at a loss to understand why the company that engineered the unusual situation that I am faced with at this point "cannot provide you with engineering support" .
Old 03-23-2012, 05:56 PM   #15
Civil Engineer
OK realoman, back up and try to understand where Superior Wall is coming from. Their wall system is perfectly standard, it is DIFFERENT than a typical cast-in-place concrete wall. It is a precast wall that comes in segments, and is typically supported on gravel, which is less expensive than casting a concrete footer for the wall. That is why Superior Wall is in business, they offer a cost competitive solution for rapidly installing a wall, so I don't know why you are so pissed off at them for building a wall the way they always build walls. And by the way, I don't own stock in Superior Wall.
As to why they won't engineer your installation, well that is their business. They supply walls that are not intended to have excavations immediately next to them. If it were a cast in place concrete wall, you would have similar issues, if the footer were on gravel and you wanted to excavate below the footer.
As to not needing an engineer to look at it, of course it is your right to excavate immediately adjacent to your foundation and "take your chances". I do not recommend this approach, as failure could lead to serious or fatal consequences, but I also appreciate that you probably think it is ridiculous to hire an engineer for what you obviously think should be a simple job. If you don't care to pay the money for an engineer, make sure your insurance will cover self inflicted damage to the house, and make absolutely certain you have an escape plan in the event the trench you are working in collapses on you, or the wall falls over on you. And try to understand that Superior Wall is not in business to design your project, they certainly do not want liability for failure any more than a DIY chat room wants to assume liability for your project, so of course they are not going to help you engineer the job.
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
