Did I Drill Too Deep? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 02:32 PM   #16
Rewards Points: 272
I would like to see the code where it says to use pressure treated wood inside a home. I have never in all my years heard of it. If you are referring to bluwood,that is something else. Bluwood is a two part, preconstruction wood protection system. The lumber has a film on it that helps prevent moister from seaping into the wood and also protects against fungus and wood eating insects.
fixrite is offline   Reply With Quote
Old 02-16-2012, 02:33 PM   #17
Rewards Points: 272
When wood is used as a sill plate the use of sill foam is ....according to code....to be used. Correct me if I am wrong here.
Old 02-16-2012, 02:41 PM   #18
Rewards Points: 14,300
The new pressure treated wood is treated with copper, so unless you ate it, lapped it or got it in a wound there is no danger from it once it's sealed in a wall.
Since your basment is dry and I think you said you used tar paper under it you may get away with it. But in some cases the dry wood soaks up moisture like a sponge and rots out when it comes in contact with the acidic chemiclas in concrete.
If I had of ever heard that conversation with a customer I would have gone screaming for the manager.
It shocks me sometimes when people on here tell us some of the misinformation they have been given at the box stores.
Old 02-16-2012, 03:07 PM   #19
Rewards Points: 272
I think this is why I do not use it.
http://www.cmhc-schl.gc.ca/odpub/pdf/65891.pdf
The Following User Says Thank You to fixrite For This Useful Post:
harvest (02-16-2012)
Old 02-16-2012, 03:23 PM   #20
Canadian and US codes must be differant. Any slab foundation home has to have pressure treated wood used as a bottom plate, as well as any basement bottom plates.
Even a garage would have pressure treated as a bottom plate.
Old 02-16-2012, 03:53 PM   #21
concretemasonry's Avatar
Rewards Points: 2,640
Just a note - there are no acidic materials in water around concrete since concrete is an alkaline material that neutraliazes the the acids from the wood treatment and other materials. Just make sure to use the proper nails or connectors that must be used to resist the corrosion from the wood treatment chemicals.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Old 02-16-2012, 06:04 PM   #22
Thank you all for your comments and advice. Since I have gone too far to make any change on what I have already done, I would ask: Do I need outdors plywood for my floor? Should the underlayment put between plywood and laminated floor be a vapor barier as well? According to the Home Depot guy: no!
harvest is offline   Reply With Quote
Old 02-16-2012, 06:44 PM   #23
Rewards Points: 272
On your subfloor you should be using 3/4" t&g ply. You should also be using PL Premium on your joists under your ply to glue it to the floor joists as well. Your ply should be attached using 2" screws into the floor joists to guard against warpage and squeaks. You do not need to use exterior grade ply.
harvest (02-17-2012)
Old 02-17-2012, 03:15 AM   #24
Typically a sill gasket (comes in a foam roll) is used under bottom plates on concrete, that's what I do. Others use PT wood (for the bottom plates only), however I don't see it done this way often around here.
For your flooring, check the manufacturers instructions, some require an underlay, some don't.
chrisBC is offline   Reply With Quote
The Following User Says Thank You to chrisBC For This Useful Post:
Old 02-18-2012, 03:49 AM   #25
Thread killer
Rewards Points: 272
Not to start a fight, but they found less than 5% of the tolerable limit for arsenic in the air of the worst house. How is that a danger I need to worry about?
Canucker is offline   Reply With Quote
Old 02-18-2012, 06:01 AM   #26
DIY staff
Rewards Points: 7,174
Code in this area call for pressure treated wood for sill plates and bottom plates when in contact with concrete----
That's been code for over 25 years,here.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (02-18-2012), drtbk4ever (12-11-2013)
Old 02-21-2012, 01:18 AM   #27
Rewards Points: 81
To fasten bottom plates for my interior walls to the concrete slab, I drilled holes through the wood and into the concrete that were just big enough for a 16d nail to drop right in and out with ease. I then used construction adhesive on the plate and stuck it to the floor, followed by driving two 16d nails through the hole in the wood and into the hole in the concrete. I drove the nails in at the same time, so they are in effect "wedged" in place. That by itself is probably enough to keep the plate in place forever, but with the addition of the construction adhesive...well, lets just say I hope I don't ever have a reason to try and pull the plates up.
JeepNick is offline   Reply With Quote
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 09:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
