Dented Stainless Steel-HELP!!! - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2006, 09:15 AM   #1
Dented stainless steel-HELP!!!
Hi everyone. i moved into my new house a few months ago. I used an installer for my new appliances that I had heard was good. It turned out he was as sloppy as they come.
There is a nice size dent in the door of my new (expensive) stainless steel fridge and my new stainless steel oven.
Can these be fixed without replacing the stainless steel?
Thanks!!!!!
yrapps is offline   Reply With Quote
Old 05-07-2006, 09:39 AM   #2
Home Improvement Guy
ron schenker's Avatar
The company that employs the installer should be held responsible and replace the fridge and stove...no charge!
ron schenker is offline   Reply With Quote
Old 05-07-2006, 12:09 PM   #3
Thanks but I used a freelancer.
Old 05-07-2006, 12:21 PM   #4
Oldguy
Rehabber's Avatar
Talk to a 'paintless dent removal' auto body shop. you may have to disassemble the doors yourself, but this would be a lot cheaper than replacements. Sorry about the hack you hired.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-09-2006, 04:22 PM   #5
agreed an auto body shop is probably your best bet, hopefully it is not that bad
1crazygirl is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
Gauge of stainless steel sink Not Sure Plumbing 2 08-29-2006 04:56 AM
stainless steel kitchen sink KANUTTER Plumbing 6 01-09-2006 03:42 AM
