Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-12-2012, 03:54 AM   #1
Demolish half brick wall
Hello,
I would like to demolish half a brick wall that stands between my living room and kitchen. I will then have a bench/counter fitted to be used as a table with stools on the side of the kitchen.
In my opinion this is way too complicated but I have attached a sketch of what is on the was so as for you to let me know if this is possible or not.
What do you suggest?
Thanks.
giannishadj is offline   Reply With Quote
Old 12-12-2012, 08:58 AM   #2
AHH, SPANS!!!
was the kitchen or living room an add on addition and the exterior brick wall was left up as part of the addition or is it a fake brick wall?
hand drive is offline   Reply With Quote
Old 12-12-2012, 12:58 PM   #3
Stuck in the 70's
Blondesense's Avatar
A couple of pics of the actual wall may help.
Old 12-18-2012, 07:00 AM   #4
I will post some pictures soon but my ultimate goal is to do this:
Old 12-18-2012, 12:00 PM   #5
This is the wall that I want to demolish. I want to remove the top half or most of the top half to make it a bar:
[IMG][/IMG]
This is the big picture:
This is the wall I want to place the TV on or on a piece of furniture:
[IMG][/IMG]
This is the other side of the wall that I want to demolish:
[IMG][/IMG]
Any ideas? I know its difficult but at least I'll give it a shot!
Old 12-18-2012, 12:24 PM   #6
concretemasonry's Avatar
What country are you in? - The heating, cooling and electrical outlets suggest that question.
The only brick I see are just surface tiles applied for a backsplash above the countertop.
Is the wall you want to open up made of masonry (brick, block, clay tile) or is a framed wall using steel studs or wood?
You definitely have a lot of electrical and heating/cooling in the wall you want to remove. It would be good to have a local professional look at the situation to determine the feasibility. the concept would certain open up the small spaces into a larger one.
Dick
concretemasonry is offline   Reply With Quote
Old 12-18-2012, 12:29 PM   #7
I live in Cyprus.
The wall is made up of masonry.
Yes I agree that there are a lot of electrical and heating/cooling in the wall. I will not remove or move any heating hubs but the aircondition might need to move.
Dick
Old 12-18-2012, 12:57 PM   #8
Well, at least my observation ability has not deteriorated with age. - I was thinking of Greece and not Turkey and just overlooked Cyprus. Most of what I saw in Turkey was different orientation and heights of outlets. Cyprus has had and long and rich history and influence by both the Greeks and Turks
You walls are probably hollow clay tile (cores either horizontal or vertical) or even solid block with a plastered surface and the channels in the tile routed out for wiring before the final plaster coats. I was always amazed how the 3" or 4" tile can be routed out with a hammer to install the electrical and mechanical to created a very sound wall. The walls could even be pumice blocks since pumice is common, desirable and available in your area. I spent some time in Yali, between Greece and Turkey where there are some of the largests resurces of high quality pumice in the world.
Depending on your abilities, you will need a local craftsman to assist you.
Dick
My garage wall bricks seems to be cracking where the brick wall contacts Unicornz0 Concrete, Stone & Masonry 2 09-05-2012 10:31 PM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Garage brick wall repair TANME General Discussion 2 02-04-2010 07:19 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
