Deep Counter Tops ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 09:25 AM   #1
Rewards Points: 240
deep counter tops ?
typical counter tops are 24" deep. has anyone made them 27" or so deep ?
i am thinking about it.
Fix'n it is offline   Reply With Quote
Old 04-21-2013, 09:53 AM   #2
Rewards Points: 528
Yes, I have. Most won't because of the reach for the females in a house may be too much.
framer52 is offline   Reply With Quote
Old 04-21-2013, 10:01 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
My garage is 30"....but I also have them at 40" in height.
You bring up a good topic....standards....
Typical counter top is 24" deep....36" high.....
Bathroom is 16-20" deep....30-32" high.....
But we as humans are getting taller.....
I'm close to starting to make the vanity in our new bathroom....they are not going to be standard...right now the depth is going to be about 20" but the height will most likely be 36". I don't like having to bend over so far.
You can do what ever you want. I think 26-27" would be fine.....unless you have some short people in your house...
Old 04-21-2013, 09:51 PM   #4
Rewards Points: 240
how about some pics ?
Old 04-22-2013, 07:00 AM   #5
Rewards Points: 3,130
Ours are 27 inches. But we are both tall.
Old 04-22-2013, 08:00 PM   #6
Rewards Points: 240
my wife is short. i had her get an onion at the back of the counter = no problem. i then placed a 2x4 up next to the counter top. again, she had no problem getting the onion.
so i am going to consider doing this.
Old 04-24-2013, 06:39 AM   #7
Out of curiosity, why are you considering this? You won't gain appreciable counter space, and your cost will go up quite a bit if you're going to have a granite countertop or something similar. And most people won't be able to tell just by looking that your countertop is different.
Old 04-24-2013, 08:22 PM   #8
Rewards Points: 240
my fridge is deep, so it sticks out from a normal counter top, a fair amount. i could make the counter deeper where the fridge goes. and i cannot recess the fridge much, exterior wall. and i KNOW i would appreciate the added space.
Old 04-25-2013, 06:55 AM   #9
Thanks. Now I understand. I'd probably do the same.
The Following User Says Thank You to md2lgyk For This Useful Post:
Fix'n it (04-25-2013)
Old 04-25-2013, 11:07 AM   #10
JOATMON
ddawg16's Avatar
That is actually a very good reason.....especially when you have one of the boat anchors like I have....
Fix....just make sure you leave enough room to be able to open the door all the way...if yours is like mine...the counter top can't stick out more than the seal...otherwise the door will hit the counter before you get it all the way open.
The Following User Says Thank You to ddawg16 For This Useful Post:
What is the standard depth of kitchen counter tops RobertN Carpentry 3 10-29-2010 10:28 AM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 06:18 PM
concrete counter tops rwongrey Remodeling 10 07-13-2009 01:25 PM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 10:13 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
