Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-18-2012, 12:57 PM   #1
Decorative mesh. Perforated metal screens.
Under the kitchen cabinets there is a radiator, and the cabinets are against a wall with no insulation.
I'm looking for HEAVIER gauge decorative perforated metal to mount where the base would go under the cabs or another solution.
The big box stores have thinner, light gauge; it doesn't seem like it would hold up to toe kicks.
Previous owners covers holes with luan and base cove. Upon removing for new flooring, I noticed "marks" and openings which indicate there was perf metal.
I bigger solution would be insulate behind cabs. I pulled out cabs once to refinish them in the garage and discovered there is evidence of years of condensation behind the cabinets.
Maybe just some styrofoam and luan inside back wall of cabinets will do the trick?
Also, maybe the radiator was supposed to keep pipes from freezing?? I'm guessing there was no styrofoam in the late fifties when this kitchen was done??
Squeakyhinge is offline   Reply With Quote
Combining old wire to new Cossack Electrical 148 08-26-2012 02:56 PM
Custom exterior metal wall panels badboi Building & Construction 0 08-08-2012 11:51 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
