Deck Access Hatch - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 06:31 PM   #1
Deck Access Hatch
I am getting ready to build a 28 x 16 ground level free standing deck. I need to frame in a removable section approx 4'x8'. I am not finding much info on this. Are there any special framing needs for this? The deck is going out 16' from the house. Section will start about 5' out and 8' in from edge. I'm using 2x8 joists 12" OC.
rman1953 is offline   Reply With Quote
Old 06-22-2010, 02:30 PM   #2
Joist spans on Deck
I'm in the process of building a freestanding (mfg home so can't attach) deck 28x16. I using 2 4x6 beams cantilevered in 2' and 16' 2x8s for the joists. Deck will be approx. 18" off ground. When I look at this it seems to me that the 12' span between the beams is too long. Lumber supplier said it should be fine. My question is should I run a 3rd beam down the middle or am I ok as is? I also was thinking of doubling the 2 end joists for more support. Joists will be spaced 12" and I'm using Azek for the decking. Any thoughts/suggestions would be appreciated. Thank you
Old 06-22-2010, 10:11 PM   #3
Registered User
Rewards Points: 4,924
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Be safe, Gary
Old 06-23-2010, 12:00 PM   #4
Thanks for the link Gary, this is just what I needed. Rich
Old 07-06-2010, 09:55 AM   #5
Cutting Deck Boards for Access
I am finally getting finished up with the framing on new deck (28x16). I framed in a section approx 4x8 to install a lift out section for access under the deck. Is it better to pre-cut the deck boards or can this section be cut after they are layed out? I've seen both just not sure which is best. I'm using Azek for the decking and as much as they cost I don't want to make a mistake. Thanks for the advice.
Old 07-10-2010, 02:18 PM   #6
Rewards Points: 5,336
An access door that is 32 sq ft will require a substantial frame and will be of a significant weight.
I'd make the frame and cut the individual slats to size.
Ron
Old 07-10-2010, 03:30 PM   #7
What is under the deck that you need access ?
Old 07-11-2010, 06:44 PM   #8
Registered User
Try to frame it in two pieces for ease of removal... I'm just across the bridge in Tacoma.. Howdy, neighbor! Welcome to the forum! Show us some pictures after finish.
Be safe, Gary
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 10:40 PM
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 11:59 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
