Deadbolt Issue - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 05:26 PM   #1
Deadbolt issue
I just replaced the single cylinder deadbolt on my back door. The deadbolt works fine from the outside but when I try to turn the deadbolt from the inside, it's very difficult and I can barely move it. What'd I do wrong?
Thanks!
jkrodger is offline   Reply With Quote
Old 01-26-2009, 05:52 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
its a tough call not knowing what type of dead bolt you installed. I would suggest removing it a rereading the directions and installing it again. If this is something that you haven't performed before, reading the directions usually brings attention to something you missed.
If i had to guess, I would think that the turning splines are not mated up. BOB
Old 01-27-2009, 12:58 PM   #3
Thanks, I'll try uninstalling and reinstalling this weekend (got hit with 6" of snow last night but this weekend it should warm up to 40). I've done deadbolts and door handles without problems before. I'm guessing the turning splines are matched up because when the key turns the deadbolt, the inside handle moves along with it. Then I can use the inside handle to unlock the deadbolt if it were locked from the outside. Hope that makes sense.
Old 01-27-2009, 03:25 PM   #4
buletbob's Avatar
what brand dead bolt is it?.
Old 01-27-2009, 04:23 PM   #5
actually, i took it off and put it back on today. I installed the same way as yesterday but this time it works. I still don't know what went wrong but it's working now so I guess .
Thanks!
Old 01-27-2009, 04:25 PM   #6
buletbob's Avatar
Thanks!
Great!
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Lennox G21Q issue gotzapped HVAC 2 11-25-2008 02:28 AM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 01:44 PM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 08:20 PM
