Damaged Plaster Under Door Casings - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 08:38 PM   #1
damaged plaster under door casings
Hello-
I am attempting to replace the door moulding/casing in my 1950s house. I'm guessing that this is the original moulding. When I pried off the old casing, the plaster underneath (it has lathe and plaster walls) has some cracks and pieces missing, and there are some large gaps between the door frame and wall. Is this something I should worry about fixing--and how do I fix this Or can I just take the new moulding and attach it over this broken/cracked/gaping plaster?
bcbatson is offline   Reply With Quote
Old 07-25-2009, 09:22 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
My assumption is that the new casing will be stained and the same width or wider than the original moulding.
It's OK to cover the gap with the new casing.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-25-2009, 10:04 PM   #3
Great. Thank you!!!
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 12:23 PM
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 01:50 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
