Cutting A Stud On Load Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 05:13 PM   #1
Cutting a stud on load bearing wall
I need to cut a stud to make room for an in wall speaker. Once cut I was going to remove the bottom portion of the stud and put a new header at the top of the opening(bottom of the existing stud) and use a new 2x4 trimmer, screwed into existing studs on each side of the new header.
Is it absolutely neccessary to support the ceiling while I do this? Studs are 16 on center and there is a second story above.
timw is offline   Reply With Quote
Old 01-12-2009, 08:18 AM   #2
Remodeling Contractor
no, but when you cut this stud you will notice it will bind the blade. You might want to angle a longer 2 X 4 into the top plate supporting it to the floor to remove the tension.
Old 01-12-2009, 08:59 AM   #3
Registered User
Termite's Avatar
If you do cut out this stud, you definately do need to header it off. In most cases removal of one bearing stud won't cause structural sagging in the short time it takes to cut it out and header it off.
Old 01-12-2009, 09:16 AM   #4
post does state a new header was to be used.
Old 01-12-2009, 09:49 AM   #5
Perhaps I'm not seeing the whole picture here. Why not locate speaker between the studs? Please explain.
butlersprints is offline   Reply With Quote
Old 01-12-2009, 02:55 PM   #6
I need to center the speaker under the TV. Unfortunately the stud is dead center where the speaker needs to go. I wish I could just put it between the studs. That would save me a lot of work including taking down and putting back a 200 pound plasma!
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-14-2011 12:31 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 10:32 PM
Load bearing Wall? flyndave2002 Building & Construction 19 02-22-2008 12:24 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
