Cutting A Stud In An Exterior Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 01:57 PM   #1
cutting a stud in an exterior wall
I'm trying to install a wall dog door between 2 garage doors. This is on the bottom floor of a two story section of the house. It seems, there are double 2x6 studs 11" apart and I need to cut one of them. My question is this: because they seem to have an overkill situation with side by side 2x6 studs and 11" on each side the same situation (double 2x6 studs), will it damage the integrity of the wall to cut one of them.
m.connley is offline   Reply With Quote
Old 10-08-2010, 02:14 PM   #2
Rewards Points: 120
What is the distance between the doors? About 17" plus the trim? It is most likely that the double studs are holding your door headers, which in turn hold up the rest of your house. This is probably not an area in which you want to make structural modifications.
Old 10-08-2010, 02:19 PM   #3
The distance is 34"
Old 10-08-2010, 02:31 PM   #4
Rewards Points: 120
Okay, that makes more sense, but still, there is a reason they doubled them up; I would definitely consult with an engineer before doing anything with those studs. You have a lot of weight resting in that area.
Old 10-08-2010, 03:18 PM   #5
Thanks, you're probably right. I may be much simpler to just get rid of the dogs! Problem solved!!!
Old 10-09-2010, 05:05 PM   #6
Rewards Points: 1,910
Or put the dog door (if it's small enough) in the garage door panel.
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
Cutting a stud on load bearing wall timw Remodeling 5 01-12-2009 01:55 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
