Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-23-2008, 01:01 PM   #1
banging thumbs
Cutting Roof Vent for Range Fan
I'm going to vent our new range hood directly through the roof. Since i still have the complete kitchen opened up, including the ceiling, I think it would be easier to do it know since I have easy access to everything. My concern is with how exact I need to be with the placement of the hole. Since the cabinets and stove are not installed yet, how accurate must I be in the measurements. I pretty much know where the hole needs to be, but if I'm off an inch or 2 left/right or front/back will I be setting myself up for problems since I'll be using rigid duct work?
bakerhouse is offline   Reply With Quote
Old 05-23-2008, 02:06 PM   #2
Moderator
Termite's Avatar
Use a plumb bob to get as close as possible. Even rigid ductwork will flex a considerable amount after it is installed, so I think you'll be fine.
Old 05-23-2008, 02:20 PM   #3
banging thumbs
That's what I hoped. Thanks.
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
low-slope roof and leaky ridge vent downers Roofing 15 02-22-2008 12:35 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
