Cutting Plastic Laminate Counter Top Edge (hot Bit Roller) - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 02:23 PM   #1
Cutting Plastic Laminate counter top edge (hot bit roller)
What is causing my new carbide plastic laminate bit to get just hot enough to do some very minor melting in the material when cutting the counter top edges? It appears the laminate wheel is getting a little hot. I did have some glue on it which is common but don't know what the cause is. I tried moving the router slowly and quickly.
It didn't destroy my work , but I can see a very slight indentation where the hot bit wheel was riding along the counter top edge.
Your suggestions and or recommendation are appreciated.
Steamer2
Steamer2 is offline   Reply With Quote
Old 03-31-2010, 03:58 PM   #2
Remodeling Contractor
not clean
not lubricated
not a quality unit
too deep a cut, trim first with tape on the edge then trim flush
lubricate with lacquer thinner as you make the cut
Old 04-01-2010, 06:41 AM   #3
Steel cutter, should be carbide; bearing binding; dull cutter edge.
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 07:51 PM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 02:42 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
