Cutting Outlet Hole In Mirror - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 11:33 PM   #1
Rewards Points: 260
Cutting outlet hole in mirror
I need to mount a 2x4 old work box in a mirror. What type of tool(s) do I need for this? Do they make a rotozip bit that can cut through mirror/glass?
bluefitness is offline   Reply With Quote
Old 02-25-2009, 12:10 PM   #2
Drywall contractor
Rewards Points: 1,070
No rotozip bit for glass, a tile bit is not the same. I know there are diamond bits made specifically for DRILLING glass. I don't think there's a jig saw blade for cutting it. Seems I've seen a couple mirrors where they drilled a couple of 2" holes, one above the other to access a square box. If it's not a huge mirror, you could take it to a glass company and get them to cut it for a nominal charge. They'd likely come to you and do it if it's too big to transport. Probably still cheaper than investing in specialty bit(s) and taking the chance of breaking the mirror anyway.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 12:09 PM
Drywall - hole for outlet bigger than faceplate slinku2020 Drywall & Plaster 6 06-30-2008 02:10 PM
Outlet Box Five Hole 1/2 in. by ACE hardware handywoman99 Electrical 8 05-31-2008 11:59 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 07:28 AM
