Cutting Out Brick For Glassblock? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 12:23 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Cutting out brick for glassblock?
My main bath is dark and the shower/tub is on the south wall where the sun hits. I want to cut out a big garden window and put 12x12" or 16x16" glass block in place of the bricks and maybe a window for ventilation. Something like this (hope this shows up):
http://www.glassblockinnovations.com...d=15&Itemid=19
This whole bathroom will be demolished, because of mold and updates. Where do I start and how do I go about cutting through the brick? Do I need support for the wall?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 03-05-2008, 04:46 PM   #2
Are we talking about a solid brick wall or a brick veneer? There will be a slight difference in how I would proceed. The brick veneer wall will be thicker for one thing.
Handyman50 is offline   Reply With Quote
Old 03-05-2008, 04:57 PM   #3
concretemasonry's Avatar
Rewards Points: 2,570
Judging by your location you may have 8" block walls - either plain 8" high or 4" high slump block.
If this is the case and you are not just removing block from under an existing opening, you would need a lintel over the opening. If you are lust working below and existing opening, you may not have to put in a lintel since one would be in place.
concretemasonry is online now   Reply With Quote
Old 03-05-2008, 05:34 PM   #4
Fixer-'til-broker
Rewards Points: 262
4" slump block, double layer wall. By lintel, you mean steel header-type sheet about 3/8" thick?
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
cutting brick to add window in bathroom DoubleD07 Building & Construction 14 08-07-2007 03:05 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 09:13 PM
