-   -   Cutting out brick for glassblock? (http://www.diychatroom.com/f15/cutting-out-brick-glassblock-18044/)
DIYtestdummy 03-05-2008 11:23 AM
My main bath is dark and the shower/tub is on the south wall where the sun hits. I want to cut out a big garden window and put 12x12" or 16x16" glass block in place of the bricks and maybe a window for ventilation. Something like this (hope this shows up):
http://www.glassblockinnovations.com...d=15&Itemid=19
This whole bathroom will be demolished, because of mold and updates. Where do I start and how do I go about cutting through the brick? Do I need support for the wall?
Handyman50 03-05-2008 03:46 PM
Are we talking about a solid brick wall or a brick veneer? There will be a slight difference in how I would proceed. The brick veneer wall will be thicker for one thing.
concretemasonry 03-05-2008 03:57 PM
Judging by your location you may have 8" block walls - either plain 8" high or 4" high slump block.
If this is the case and you are not just removing block from under an existing opening, you would need a lintel over the opening. If you are lust working below and existing opening, you may not have to put in a lintel since one would be in place.
DIYtestdummy 03-05-2008 04:34 PM
4" slump block, double layer wall. By lintel, you mean steel header-type sheet about 3/8" thick?
