Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-07-2005, 08:26 PM   #1
underqualified shoprocket
Cutting into the basement floor
to install plumbing for the basement bathroom.
Is there one specific tool that is better/easier/faster in regards to cutting into the concrete??
should i go at it with the sledgehammer?
or rent something a little more hightech from homedepot??
any thoughts?
hallbum is offline   Reply With Quote
Old 10-07-2005, 10:54 PM   #2
Contractor
Rent a small hammer. Assuming that you are on a 4" slab, start 3" inside the projected hole. Put a hole in the center and work your way out to the perimeter, removing the material as you go. If you can drill a hole in the center of your project, you will create less stress to your slab.
Teetorbilt is offline   Reply With Quote
Old 10-07-2005, 11:05 PM   #3
An electric jackhammer will make short work of it. Try to get one about 60#. 30# might be a little light, 90# is somewhat cumbersome but effective.
pipeguy is offline   Reply With Quote
Old 10-07-2005, 11:14 PM   #4
You can rent a diamond concrete saw that will make a much smaller and neater opening and won't have trouble with reinforcing steel. Some are circular blade type and some are chain type.
mighty anvil is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 06:06 PM
cutting a concrete basement floor Rembrandt Introductions 1 10-23-2005 01:58 PM
Cutting into the basement floor.... hallbum Flooring 8 10-11-2005 01:01 AM
