-   -   Cutting into the basement floor (http://www.diychatroom.com/f15/cutting-into-basement-floor-1114/)
hallbum 10-07-2005 07:26 PM
to install plumbing for the basement bathroom.
Is there one specific tool that is better/easier/faster in regards to cutting into the concrete??
should i go at it with the sledgehammer?
or rent something a little more hightech from homedepot??
any thoughts?
Teetorbilt 10-07-2005 09:54 PM
Rent a small hammer. Assuming that you are on a 4" slab, start 3" inside the projected hole. Put a hole in the center and work your way out to the perimeter, removing the material as you go. If you can drill a hole in the center of your project, you will create less stress to your slab.
pipeguy 10-07-2005 10:05 PM
An electric jackhammer will make short work of it. Try to get one about 60#. 30# might be a little light, 90# is somewhat cumbersome but effective.
mighty anvil 10-07-2005 10:14 PM
You can rent a diamond concrete saw that will make a much smaller and neater opening and won't have trouble with reinforcing steel. Some are circular blade type and some are chain type.
