Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-23-2006, 10:03 AM   #1
Cutting drywall
I am trying to cut thru drywall above a door entrance which has a solid piece of wood on top of it, I cannot use the drywall saw because the saw just goes thru the drywall and stops when it hits the wood, giving me no working gap for the sawing motion. Can anybody suggest a better way,
Appreciate all the help I can get,
kind rgds
shyla
hdayanan is offline   Reply With Quote
Old 02-23-2006, 11:17 AM   #2
Contractor
tgeb's Avatar
Cutting drywall
I would use a razor/utility knife.
It may take six or eight passes to get all the way through but you will have a nice clean cut when done.
Tom
Tom
tgeb is offline   Reply With Quote
Old 02-23-2006, 06:07 PM   #3
IHI
Cutting drywall
right on!! just hoping it's a narrow door lol.
IHI is offline   Reply With Quote
Old 02-23-2006, 06:51 PM   #4
Contractor
Cutting drywall
The old RotoZip will be a bit dusty but fast. Use the blue bits and set your depth.
Teetorbilt is offline   Reply With Quote
Old 02-24-2006, 02:43 AM   #5
Cutting drywall
You could attach a piece of wood to the bottom of a jigsaw to reduce the cutting depth. If you drill a piolet hole and use this method you can cut the drywall out and worry about the wood afterwards.
sendflowers is offline   Reply With Quote
Old 02-24-2006, 10:19 AM   #6
Smile
Cutting drywall
Thank you guys, I used a combination of all the methods, used a dremel upto some depth and used a utility knife to cut thru,
you guys are great,
kind rgds
shyla
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Cannot get my drywall into the basement. jeremy56 Building & Construction 17 04-02-2007 05:08 PM
Cutting drywall to put in windows down a stairwell ragtopdave06 Remodeling 9 02-14-2007 08:32 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
