-   -   Cutting drywall (http://www.diychatroom.com/f15/cutting-drywall-1919/)
hdayanan 02-23-2006 09:03 AM
Cutting drywall
I am trying to cut thru drywall above a door entrance which has a solid piece of wood on top of it, I cannot use the drywall saw because the saw just goes thru the drywall and stops when it hits the wood, giving me no working gap for the sawing motion. Can anybody suggest a better way,
Appreciate all the help I can get,
kind rgds
shyla
tgeb 02-23-2006 10:17 AM
I would use a razor/utility knife.:)
It may take six or eight passes to get all the way through but you will have a nice clean cut when done.:)
Tom
IHI 02-23-2006 05:07 PM
right on!! just hoping it's a narrow door lol.
Teetorbilt 02-23-2006 05:51 PM
The old RotoZip will be a bit dusty but fast. Use the blue bits and set your depth.
sendflowers 02-24-2006 01:43 AM
You could attach a piece of wood to the bottom of a jigsaw to reduce the cutting depth. If you drill a piolet hole and use this method you can cut the drywall out and worry about the wood afterwards.
hdayanan 02-24-2006 09:19 AM
Thank you guys, I used a combination of all the methods, used a dremel upto some depth and used a utility knife to cut thru,
you guys are great,
kind rgds
shyla
