Cutting Ceramic Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 08:09 PM   #1
I have to trim 3/16 of an inch on my tiles. Impossible to cut with a hand type tile cutter. I believe I have no choice but to rent an electric tile cutter from home depot unless someone has any other suggestions.
blue collar is offline   Reply With Quote
Old 03-19-2012, 08:18 PM   #2
DIY staff
Rewards Points: 7,174
You need a wet saw----if you only need a few---Lowes and the Depot have saws set up and will make a few cuts for a small fee---
Old 03-19-2012, 08:20 PM   #3
10-4 Thks Mike !
Old 03-19-2012, 09:58 PM   #4
Rewards Points: 960
I would just score it and nip it off. I did a bunch of these as the first course on a shower last week. You put in a level line to start with, and laid the second course, allowing for a full tile, and oftentimes there is some abnormality in the floor and you have to take some off the first course.
Better to take some off than have a 1/2 grout joint on the bottom.
cleveman is offline   Reply With Quote
Old 03-21-2012, 06:45 PM   #5
Rewards Points: 512
you can nip it or if you have a grinder put a diamond blade on it and cut the tile with that, i cut all my tile that way. you can curves cut and odd shapes and shave a wee bit off the edges to.
princelake is offline   Reply With Quote
Cutting ceramic tile with a scroll saw? HandyHunter Flooring 14 12-06-2011 08:56 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 07:58 PM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
