Cut Nails On Old Concrete - PAT Guns - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 06:57 PM   #1
Rewards Points: 278
Cut Nails on Old Concrete - PAT Guns
If using cut nails on old concrete and getting blowback - if I use a PAT gun, will I still be getting blowout ?
mobiledynamics is offline   Reply With Quote
Old 03-04-2012, 07:07 PM   #2
DIY staff
Rewards Points: 7,174
Occasional blow outs will happen with some concrete when using powered stud guns--
Much less likely than cut nails--those are usually used in green concrete,not old cured concrete.
best way to remove nails in concrete block BlueBSH Building & Construction 29 09-19-2014 06:23 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 10:26 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
