Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-18-2008, 01:37 AM   #1
Question
Curved wall and Suspended Ceiling?
Hello.
I'm thinking of building a curved wall in my basement for my office. I want to have a suspended acoustical ceiling installed but I'm not sure if you can do round corners with that? The radius is about 11' and and end to end length of wall of about 13'.
Matt
mfleming is offline   Reply With Quote
Old 06-18-2008, 07:48 AM   #2
gravity always wins
There are wall angles made for lay in ceilings that are flexible for curved wall applications. Try Armstrong, USG, or Bailey.
Old 06-19-2008, 11:42 AM   #3
I checked their site and I cant seem to find anything. I have heard of people using the t/o drywall for bearing of the ceiling tiles but that could be really finiky.
Old 06-19-2008, 01:34 PM   #4
gravity always wins
I put a call in to the local Armstrong rep asking him for a part number and a spec sheet. I'll post what I learn.
Old 06-23-2008, 07:52 AM   #5
gravity always wins
I've learned that Armstrong does not manufacture a flexible wall angle, but a company called trim-tex makes one that he'd recommend. The rep passed this info along:
Trim-Tex 9/16" part # 8159, 15/16" part#8158
www.trim-tex.com
Old 12-09-2011, 02:35 PM   #6
I called all of the manufacturers I could find for ceiling grids and they all said that they did not have this solution and referred me to Trim-Tex. Trim-tex only sells to suppliers and most supliers will only sell by the 63 item case to contractors. However, they have excellent customer service and they sent me a few 4' sample peices for my project. I would recommend finding your local supplier on their website to see if they stock the needed item or call Trim-Tex and see what they recommend. They are very helpful.
dauber185 is offline   Reply With Quote
Old 12-09-2011, 02:43 PM   #7
Tileguy
Bud Cline's Avatar
Why can't you make your own using a piece of wood trim or rip a 1" X 1" from pine and use it.
Old 12-09-2011, 03:53 PM   #8
STAFF
BigJim's Avatar
You can also cut curfs in the back of the metal wall strip almost to the front edge and it will curve around by letting the back of the metal strip overlap the cuts. Just a thought.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 12-09-2011, 03:55 PM   #9
Tileguy
Bud Cline's Avatar
Been there done that - that's ugly.
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (12-10-2011)
Old 12-10-2011, 11:31 AM   #10
Framing Contractor
Do the ceiling first and then build the wall under
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
loneframer (02-25-2012)
Old 12-10-2011, 12:02 PM   #11
i am in commercial construction where eveything is metal, we use flex track for top and bottom of the walls. you can also notch the bottom track but it more time consuming. you cannot buy this stuff at the Depot but havde to go to a supplier that carries metal framing material. for the wall mold, you need to get flexible molding with the same profile as the acoustical framing you plan to use. in ATL it can be purchased at Capital material.
woodmeistro is offline   Reply With Quote
Old 02-25-2012, 06:04 AM   #12
Suspended ceilings are like a second ceiling and the idea of a suspended ceiling is to make your premises appear more professional and well suited to a working environment.
annie wilson is offline   Reply With Quote
dans basement office danmc Building & Construction 3 05-05-2008 01:01 PM
